BBump
Feb 20, 2022Aspirant
NAT Type issues Nighthawk AC1900
So I got a nighthawk modem router to upgrade from my older router. Ever since starting to use this new(er) router i have been having NAT type issues across all platforms. I was able to "resolve" the ...
Feb 20, 2022Guru - Experienced User
What devices are you seeing problems with NAT type on?
Has a facory reset and setup from scratch been performed and just use default settings with out any Port Fowarding?
Did you disable uPnP prior to configuring Port Foward configurations?
How did you set up Port Foward Configurations?
Do you see NAT Filter feature menu listed on the modems web page under Advanced tab/Setup/Wan Setup?
BBump
i have tried with and without uPnP, i dont see any NAT filters anywhere unless im looking in the wrong spot. and having NAT issues on every device/game console. ive gone thru rebooting, factory resetting, and my ports are set up with direct ports to the gaming networks being used such as Xbox Live and Playstation Network. Ive even tried setting up directly to the game server ports such as Call of Duty or Destiny for example
- FURRYe38Feb 21, 2022Guru - Experienced User
There maybe a FW issue with the router side.
You may need to contact NG support. https://my.netgear.com/support/contact.aspx
The router side is'nt known for good gaming configurations. The uPnP feature should be working as well however may not be. You may need to use the modem portion of the C7100 and connect up a external router that has better gaming handling abilities. I wish the C series had NAT Fiilter however they don't as this would be helpful. NGs R, AX and XR series routers have NAT Filter features which would be helpful if you have two or more game devices or consoles online at the same time.
- BBumpFeb 22, 2022Aspirant
i have tried to contact support but it is out of the 90 day warranty so they no longer provide support for my router any more. Thats when they directed me to here for help
