BBump
Feb 20, 2022Aspirant
NAT Type issues Nighthawk AC1900
So I got a nighthawk modem router to upgrade from my older router. Ever since starting to use this new(er) router i have been having NAT type issues across all platforms. I was able to "resolve" the ...
Feb 21, 2022Guru - Experienced User
There maybe a FW issue with the router side.
You may need to contact NG support. https://my.netgear.com/support/contact.aspx
The router side is'nt known for good gaming configurations. The uPnP feature should be working as well however may not be. You may need to use the modem portion of the C7100 and connect up a external router that has better gaming handling abilities. I wish the C series had NAT Fiilter however they don't as this would be helpful. NGs R, AX and XR series routers have NAT Filter features which would be helpful if you have two or more game devices or consoles online at the same time.
BBump
Feb 22, 2022Aspirant
i have tried to contact support but it is out of the 90 day warranty so they no longer provide support for my router any more. Thats when they directed me to here for help
