RoseySofty
Feb 05, 2016Follower
Neatgear Gateway c3700-100NAS
Unable to connect to PSN Playstation says firewall issue comcast says set to dmz and port porwarded all ports nether worked.
DarrenM
Feb 11, 2016Sr. NETGEAR Moderator
Hello Roseysofty
You should be able to make the NAT open on the playstation by port fowarding or having it put in the DMZ. Here is some article plus the ports you need for the PS4 may want to try again.
Application TCP Ports UDP Ports
PlayStation 4 80, 443, 1935, 3478-3480 3478-3479
http://kb.netgear.com/app/answers/detail/a_id/1118
http://kb.netgear.com/app/answers/detail/a_id/24046
DarrenM
