bulletsnbait
Mar 25, 2018Aspirant
Need access to router settings
I have an N300 WiFi router. I need to get into the settings to reset the password and to make sure it's set at 2.4 and not 5.0 so that I can use the owlet for my baby. When I go to routerlogin.net,...
michaelkenward
Mar 26, 2018Guru - Experienced User
There is nothing that you can do with the C3000, if that is what you have, that will "make sure it's set at 2.4 and not 5.0". Actually, does the modem even support 5 GHz? The manual is a bit confusing, but suggests maybe not.
A router's wifi broadcasts both. It is down to the owlet to connect to the 2.4 GHz wifi. If it doesn't work at 5 GHz it won't see that band. There is no point in disabling 5Ghz.
There is a manual and other support stuff for the C3000 somewhere at the end of this link:
>>> C3000 | Product | Support | NETGEAR <<<
michaelkenward
Mar 27, 2018Guru - Experienced User
Perhaps I should add that the confusion in the manual, which should contain more recent details than the data sheet, is down to the statement on page 57:
"A guest network allows visitors at your home to use the Internet without using your wireless security key. You can add a guest network to each wireless network: 2.4 GHz b/g/n and 5.0 GHz a/n."
This is the only mention of 5 GHz in a manual that otherwise refers only to 2.4 GHz.
I suspect a proofreading error, and boilerplate text being copied from one document to another. But the text is there.
