seeseewhy
Nov 21, 2019Aspirant
Need Help C3000 - Phone cannot connect to internet
Hi Guys Need Some Help Here. I recently purchased a C3000 modem/router for wireless connection. I purchased and activated the device on 11/3 and everything was fine. Strangely, over the l...
Nov 22, 2019Guru - Experienced User
What security mode are you using? WPA2 and AES is recommended...
What are you using for a SSID name? Should be something unique and no special characters in the name. Just plain text name.
seeseewhy
Nov 22, 2019Aspirant
Thank you, I have tried switching channels and it still doesn't seem to work.
My security setting is already WPA2 and AES
- FURRYe38Nov 22, 2019Guru - Experienced User
What happens if you temporarily disable WPA2 on the modem and see if the phone connects to the OPEN SSID name? Re-enable WPA2 and AES after testing.
