diflorini
Dec 02, 2017Follower
need help re: firmware update for WNR2000v5
A recent email from NetGear said I should install WNR2000v5 Firmware Version 1.0.0.62 NetGear says: "To avoid wireless disconnect issue during the firmware download process, NETGEAR recommends that...
antinode
Dec 02, 2017Guru
> [...] Any advice on whether I need to try the update via my wiFi
> connection or whether I should skip the firmware update?
I'd try to find a friend or colleague who has a computer with a
working Ethernet port, and use that to do the update. Once the firmware
kit is on the computer, you don't need Internet access; all you need to
do is connect a cable from the computer to the target router, and follow
the update instructions.
