jaydubzok
Aug 18, 2023Aspirant
Need help with CM1000v2, packet loss + high latency with spectrum ISP
Hello, I need help determining my issue with my internet, is any of these values out of wack?? <tabindex=-1>Startup Procedure</tabindex=-1> Procedure Status Comment Acquire Downstr...
Aug 18, 2023Guru - Experienced User
No.
Whats the Event logs page look like?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?
Are you testing for PL with a wired PC connected directly to the back of the modem with out any router in the middle?
