Psidude25
Jul 13, 2016Follower
Need help with connecting phone line to CGD24G – Wireless Cable Modem Gateway
Hi have a CGD24G – Wireless Cable Modem Gateway provided by my cable compnay that is functioning perfectly and i have had it for about a year. I recently was given the idea to connect it to my main PC with a telephone cord in order to connect the main PC to the internet and everytime i attempt to do so it will not connect and gives me "Connection failed with error 651". Could anyone help me with this? This is still a Windows 7 PC if that helps in anyway and the phone cord I bought was a normal phone cord from Walmart. Do I need a special phone cord in order to properly connect it?
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello Psidude25
You need a Cat5 or Cat6 Ethernet cable not a phone cord to connect your pc to the router it looks the same as a phone cord it is just wider.
DarrenM
