dinghankar
May 19, 2023Follower
Need help
I've recently upgraded to the Netgear Nighthawk C7000v2 and upgraded my Xfinity plan from 75mbps to 1000mbps. For some reason I get the full 800-1000mbps speed on my desktop that's connected to the E...
May 19, 2023Guru - Experienced User
What is the brand and model of the wireless device?
FYI, you'll never see anything near 1000Mpbs on 5Ghz AC due to it's limitation design and client side hardware design and support. Most device may top out at 300-400Mpbs depending on there design and support.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
https://www.increasebroadbandspeed.co.uk/realistic-speeds-wi-fi-5-and-wi-fi-6
https://www.duckware.com/tech/wifi-in-the-us.html
