ILoveLucyMN
Jan 06, 2025Follower
Need powerful wifi Solution for cement walls with Mediacom cable
I need help. What is the best solution to get powerful wifi on single level cement wall home with Mediacom cable internet. One room with direct site line access to the modem gets a good signal but se...
Jan 07, 2025Guru - Experienced User
Best solutions?
1. buy a cement bit and run cable through each room for an access point in each
2. use MoCa adapters (ethernet over coax)
3. try powerline adapters
Cement blocks wifi very well (as you've found out). Wifi broadcast strength has been set for quite a while from the FCC so there isn't any "more powerful" devices for penetration. If you're not renting but owning, investing in a long term solution is a better option
