epochdad
Jan 23, 2022Aspirant
Need to change MAC address on NETGEAR Nighthawk C7800
I left an open email relay on my machine and of course it was exploited and now my static IP is listed in sorbs and spamhaus. I have begged them to delist my IP but they said they can't and I have t...
- Jan 23, 2022
Netgear has set up a community forum specifically for the Cable Modem products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Thank you.
Jan 31, 2022Guru - Experienced User
Any progress on this?
epochdad
Feb 01, 2022Aspirant
You can close it or even delete it if you want, I went to the other forum like you suggested.
- FURRYe38Feb 01, 2022Guru - Experienced User
Did you find any information?
- epochdadFeb 01, 2022Aspirant
Unfortunately not. "MAC address is hardcoded with no option to spoof it"
In a hacker forum someone suggested to use Open WRT for firmware to have control over this.
You'll need a OpenWRT supporting router to do that. Most modems are not supporting of 3rd party FW.
