larrycole's avatar
larrycole
Follower
Feb 03, 2021
Need to find Network Security Key on cable modem CM 500V to install new mesh network
I cannot connect my computer to my new eero mesh network without providing the network security key. I can't find it when connecting directly to the modem using the IP address
1 Reply
  • > Need to find Network Security Key on cable modem CM 500V to install
    > new mesh network
       That might be difficult.  Who says that a CMxxx _modem_ _has_ any
    kind of "Security Key"?
    > I cannot connect my computer [...]
       Not a very detailed description of that device.
       "cannot" is not a useful problem description. It does not say what
    you did.  It does not say what happened when you did it.  As usual,
    showing actual actions (commands) with their actual results (error
    messages, LED indicators, ...) can be more helpful than vague
    descriptions or interpretations.
    > [...] to my new eero mesh network [...]
       Not a very detailed description of that device (those devices?).
    > [...] without providing the network security key. [...]
       _Whose_ "network security key"?
       Are you following any set of instructions?
       Visit http://netgear.com/support , put in your (modem) model number,
    and look for Documentation.  Get the User Manual (at least).  Read.
    Look for anything like a "network security key"?
       If you're trying to make a wireless connection between your
    (unspecified) "my computer" and your (unspecified) "my new eero mesh
    network" router, then you'd seem to have an argument between two
    non-Netgear devices, and, if so, then you're looking for advice in a
    sub-optimal place.
       Presumably, documentation exists someplace for your (unspecified) "my
    new eero mesh network" equipment, too.
    > [...] I can't find it when connecting directly to the modem using the
    > IP address
       That makes much less sense than you might think.  For the
    non-psychics in your audience who can't see any of this, physically,
    what's "connected" to what, exactly?  (Hint: If a device has different
    types of Ethernet ports, then "connected to device" is not enough
    detail.)  And then what did you do?  _Whose_ "the IP address"?  What was
    that "the IP address", and what, exactly, did you do with it?
