Onecoolstang
Apr 18, 2025Follower
Need to find replacement power adapter modem CM2000
I need help finding a replacement power adapter for my modem. CM2000. My silly cats decided to eat it and I’m struggling to find a replacement.
Apr 18, 2025Guru - Experienced User
Did they chew into the cord?
Look on places like Amazon first. Find same volts and amps as seen on the power adapter brick.
If the cord is chews, one could cut the cord and splice the two ends together again and wrap with some electrical tape. Keeping the two halves (+/-) separate.
