FlatheadLake's avatar
Jan 05, 2021
Need to Replace 7.4x5.1 DC Plug on CAX80 Power Supply
I need to replace the DC 7.4mm OD x 5.1mm ID (5.0 mm actual) barrel connector without a center pin that is on my Netgear Nighthawk CAX80 power supply.  How can I purchase this from Netgear or anywher...
  • FURRYe38's avatar
    Opening the case on the modem would void any warranty.
    Would be just easier to replace the power adapter of the one that came in box doesn't work.
