ericbrooke
Oct 08, 2020Aspirant
Need to restart CM1200 on a regular base to get 100% Internet speed both Up and down
I have had for 6 months. Every now and then I see my internet drops to 10% speed - 20/30 MPS. I notice most weekends as thats when I play games. I pay for 300 MPS. When I turn on and off and it somet...
ericbrooke
Thank you for taking the time. LAG was enable and I am not using it, will turn off.
There is a splitter, and its hs only one output.
Will your other suggestions. Thank you
Oct 08, 2020Guru - Experienced User
Ok, disabling of LAG should help along with any splitter removal.
There was a known issue with LAG enabled and in use on the 1200 however it was fixed in recent FW. I hope enabled or disabled, LAG should be a factor. Hopefully the router FW update will be helpful as well.
- ericbrookeOct 09, 2020Aspirant
So far the switch off the LAG has helped the most.
Regarding Firmware on NetGear page https://kb.netgear.com/000036375/What-s-the-latest-firmware-version-of-my-NETGEAR-cable-modem-or-modem-router
it states for ComCast ->
V2.02.05
and I have V3.02.01
- FURRYe38Oct 09, 2020Guru - Experienced User
Good to hear. Yes, I believe v3 was just released not too long ago so NG hasn't updated that web page yet.
