Laemon
Mar 30, 2015Novice
Need to upgrade C300 firmware, ISP refuses to help, Netgear support won't help
So, long story short, Netgear website says that there is no way to manually upgrade the firmware, that the ISP has to do it. The firmware is the incorrect version needed, ISP refuses to help because ...
Babylon5
Apr 27, 2015NETGEAR Employee Retired
As has been stated several times now, Netgear cannot (and do not) provide updated firmware to end users, so Tech Support cannot help in that direction either. However if people who own these types of router can post the actual details of their issues here, and I mean detail – not ‘I have the same issue as XYZ’, then I can get information back to Netgear engineers, start new threads and provide as much detail as possible. That way there is a much greater chance of fixes appearing in a new version of firmware sooner. Those people still in contact with Tech Support should try to explain the issues and if told that their router is out of warranty period ask that the issue is logged and reported to Netgear Engineering.
