Retired_Member
Dec 30, 2018Netflix has stopped working when devices are connected through switch
Hi, last week, after working fine for many months, Netflix stopped working on any devices that are connected to my cable modem via my Netgear GS108 unmanaged switch.
Netflix still works absolu...
- Retired_MemberJan 07, 2019
Well, I fixed it.
The firewall settings had been changed on my Hyperoptic 'home gateway' (cable modem/router).
antinode
Dec 30, 2018Guru
> [...] any devices that are connected to my cable modem [...]
Not a very detailed description of anything. What is your "my cable
modem"? Is it a modem, or a modem+router?
> [...] when these devices are connected through the Netgear GS108
> switch. [...]
"when these devices are connected" _to_ _what_ "through the Netgear
GS108 switch"?
What, exactly, is connected to what, exactly? (Hint: If a device has
multiple Ethernet ports, then "connected to device" is not enough
detail.)
If your (unspecified) "my cable modem" is a modem (not a
modem+router), then you can expect trouble if you connect multiple
devices to it through a network switch. Your (unspecified) cable-TV ISP
service probably allows you one public IP address, which will be granted
to the first of your gizmos which they see. After that, there'll be a
fight over that one address, leaving all but one device unsatisfied.
If your (unspecified) "my cable modem" is a modem+router, then you
should be able to connect many devices to it through a network switch.
> I have tried switching everything off and back on again, [...]
Swell. What _is_ "everything"?
- Retired_MemberDec 31, 2018
> What is your "my cable modem"? Is it a modem, or a modem+router?
It's a ZTE ZXHN H298A V1.0 V1.0.25_HOP.1T3 supplied by https://www.hyperoptic.com
> "when these devices are connected" _to_ _what_ "through the Netgear GS108 switch"?
When my television, two disc players and a home cinema amp are all connected to the GS108 switch, which is in turn connected to a LAN port on the ZTE modem.
> then you can expect trouble if you connect multiple devices to it through a network switch....
Yeah, but everything worked fine for months until last week. :) (Which suggests either my ISP pushed out some firmware or config change, I guess, or Netflix changed something at their end...) On the admin dashboard page for the modem, I can see all four devices have been assigned a unique IPv4 address by DHCP.
42, of course.
But also: the ZTE modem, the Netgear GS108 switch, a NAS, my desktop PC, two mobile phones, a Kindle, a television, two BluRay players and a home cinema amp. All of which, when powered back up in a sensible order, appeared to obtain connectivity fine, except that Netflix wouldn't work on the ones going through the GS108 switch.
Well, I fixed it.
