syntax
Dec 10, 2022Aspirant
NETGEAR - Nighthawk AC3200 Wi-Fi Router with DOCSIS 3.1 Cable Modem
I like to know what type of modem is in the Nighthawk AC3200?
Dec 10, 2022Guru - Experienced User
AC3200 is a speed, not a model. what actual model are you referring to?
And what you mean by type of modem. If its a docsis 3.1 as you put in your title, thats what type of modem it is.
syntax
Dec 19, 2022Aspirant
Sorry it the C7800-200NAS docs 3.1
- plemansDec 19, 2022Guru - Experienced User
Your correct in the the C7800 has a docsis 3.1 modem internal to it. What more details are you wanting about it?
- syntaxDec 19, 2022Aspirant
I got spectrum gigabit plan 935 download 35 uploads I want to know what modem come with this combo modem and router and is there any bugs in the flimware that brick it?
- plemansDec 20, 2022Guru - Experienced User
Its a docsis 3.1 device. That should support your speeds.
If there was known bugs, they'd have fixed them as its been out a while. there is always the few posts about devices being bricked. Tends to be because hardwire does fail sometimes.
