Grufff's avatar
Grufff
Follower
Jun 06, 2020
Netgear 1200CM modem and I cannot connect to my playstaton 4 pro with ethernet cable
I purchased the Netgear 1200CM Modem to connect to PS4 Pro with Ethernet cable and not working.
I have good wifi.  times out for the IP address everytime.
Pleae help.
1 Reply
  • > I purchased the Netgear 1200CM Modem [...]
       "CM1200"?
    > [...] to connect to PS4 Pro with Ethernet cable and not working.
       Which kind of "not working" is this?  As usual, showing actual
    actions (commands) with their actual results (error messages, LED
    indicators, ...) can be more helpful than vague descriptions or
    interpretations.
       What, exactly, did you connect to what, exactly?  (Hint: If a device
    has different types of Ethernet ports, then "connected to device" is not
    enough detail.)
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual.  Read.  Pay particular
    attention to what the User Manual says about how to use its "LAN ports".
    (And, what it doesn't say.)
       "wifi" suggests that you have a wireless router.  You should probably
    connect your (unspecified) router (WAN/Internet port) to "LAN 1 port"
    on the CM1200.  And connect nothing else to the CM1200 LAN ports.
       Connect your client devices to your (unspecified) router (LAN ports).
