Rojojobo
May 16, 2022Aspirant
Netgear 450/CG3000DV2 router inaccessible/changed admin
I bought this router used on Amazon and the idiot who sold it had changed the login info and not changed it back. I tried the 7 second factory reset on the back but that didn't do the trick. Is there...
- May 16, 2022
Try a 10-15 second press of the reset button then release. Might do this with the modem disconnected from the ISP coax line.
FYI this model modem is fairly older in generation. You might want to send it back and find something newer.
May 16, 2022Guru - Experienced User
- RojojoboMay 17, 2022Aspirant
Thanks - the longer reset hold worked. I was surprised because the lights still come back on at 7 seconds. I don't want to spend on a newer one because the cable internet in our neighborhood is so crappy and expensive it doesn't make much sense to...
- FURRYe38May 17, 2022Guru - Experienced User
Glad you got it working. đ
