bh3400
Sep 16, 2015Aspirant
netgear 600 c3700
c3700 wifi on/off light flickeing. connection speed is reduced from 29mbps to 24 mbps and brower
response is degraded. I have tested ISP with ethernet cable and connection working properly at 29mbps.
I do not want to reset unit back to factory settings is there another action I can take.?
- DarrenMSr. NETGEAR Moderator
Hello bh3400
Have you tried to change the wireless channel? The current channel could be a little congested causing the speed loss. hope to hear your feedback.
DarrenM
- bh3400Aspirant
No...I tried to change channels on both 2.4 and 5.0 Ghz and that had no effect.
Speed is variable during the day...from about 22Mbps to 28 mbps,,which is about max for
my ISP.
Beginning to think problem is more with Win 10 incompatiblity with Googe Chome. Though,
IE run slowly too.
C3700 wifi led light continues to flicker on / on as do the leds for 2.4 and 5 ghz signals.
I do not wish to reset netgear to factory settings and start over again unless there is some
reason to think that will fix the problem.
Hello bh3400
If you have upgraded to Win 10 have you made sure you have downloaded the latest drivers from your PC manufacture for your wireless?
DarrenM
