WayOverTheHill
Apr 17, 2022Aspirant
Netgear AC1200 Model C6230
Great! My model isn't showing in the drop down list. Netgear AC1200 WiFi Cable Modem / Router Model C6230 connected to an HP Pavillion 500 PC series model 500-336 running Linux Una 20.3 OS. Th...
Apr 19, 2022Guru - Experienced User
I'm still not clear if you used the same enclosure or not.
Did you format the drive properly?
https://kb.netgear.com/24059/What-are-the-USB-drive-requirements-for-ReadySHARE-on-my-NETGEAR-router
https://kb.netgear.com/18985/Which-USB-drives-are-verified-to-work-with-NETGEAR-ReadySHARE
This guide might help too.
https://kb.netgear.com/20391/ReadySHARE-USB-Storage-GUI-explained
Instead of taking a hammer to it and having to buy a new router, invest in a cheap NAS enclosure. Much better performance then cobbling together a router based NAS
WayOverTheHill
Apr 19, 2022Aspirant
No, I didn't use the same enclosure. You need to read posts completely before you start responding.
As I previous stated, the 2 Tb. drive is a 2.5 inch drive while MOST newer drives of 1 Tb. or less are 1.5" high. The enclosures I usually use are too small for the 2 Tb. drive.
I've been involved with computers since 1974, before there were any computers other than main frames and minis.I knew how to format a drive before you were born.
Please don't gloss over the fact that a 1 Tb. drive previously worked and doesn't now.
Both are set up with a gpt partition table and an NTFS format. NTFS is so that the drive is visible to both Linux (my OS as long as it's been around) and Windows should I need to work on something sent me from a Windows user). Both desktops are dual boot with both having Linux Mint Una (20.3). One has Windows 7 and the other Windows 10.
NTFS is a format that Netgear says is acceptable and again, IT WORKED PREVIOUSLY AND NO LONGER DOES!
I don't work with people who insult me (how stupid do you have to be NOT to know how to format a drive) and send me to links that don't help, (the model number of the Netgear router is C6230 as it says in the message title. It ISN'T on your list of models with "approved" drives).
Given your "GURU" status I'm presuming you're an employee or otherwise affiliated with Netgear because you've looked for a cause everywhere EXCEPT my cable modem / router.
I trust you'll forgive me if I don't respond any further to your posts. I've addressed TWO of your questions before you asked. All you've done is make it appear as though it couldn't be the equipment that once worked and no longer does.
Thanks for nothing!
- plemansApr 19, 2022Guru - Experienced User
You realize this is the public help forum where members of the public help out? We're not paid to help.
Being rude is only get people to avoid your posts. Myself as well.
Good luck
