WayOverTheHill
Apr 17, 2022Aspirant
Netgear AC1200 Model C6230
Great! My model isn't showing in the drop down list. Netgear AC1200 WiFi Cable Modem / Router Model C6230 connected to an HP Pavillion 500 PC series model 500-336 running Linux Una 20.3 OS. Th...
Apr 18, 2022Guru - Experienced User
The 1 tb still works?
did you just change out the drive and use the same enclosure or did you buy a new enclosure?
WayOverTheHill
Apr 28, 2022Aspirant
- michaelkenwardApr 29, 2022Guru - Experienced User
Was there supposed to be some text in there?
If so, try again, and keep it short and clear. Include only relevant information.
