Sugarplum41
Jan 28, 2017Follower
Netgear AC1600 C6250
Where do I go or what do I do to update my router and modem.
DarrenM
Feb 13, 2017Sr. NETGEAR Moderator
Hello MetalGuitarMax
You may want to try a factory reset on the unit. If that is not working I would suggest contacting Netgear support.
https://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic
DarrenM
