Retired_Member
Sep 15, 2016NETGEAR AC1750 / C6300 wifi cable modem router LAN connectivity problems
Any suggestions or advice on helping me sort this out would be greatly appreciated. I installed my new modem/router a few months ago and noticed that when I try to stream movies over my Xbox 1 or Ras...
VE6CGX
Sep 15, 2016Master
What is the result of speed test?
- Retired_MemberSep 15, 2016
I'll check it out tonight I did it when I first got the modem/router but I dont recall what it was
OK, when I got home tonight I ran speedtest.net on my laptop using both wireless and wired connections. All tests were to the same server.
Wired
Ping 26ms, DL 3.79Mbps, UL 5.34Mbps
Ping 20ms, DL 4.98Mbps, UL 5.75Mbps
Wireless, with computer 3' from router
Ping 38ms, DL 3.42Mbps, UL 5.72Mbps
Ping 27ms, DL 2.69Mbps, UL 5.60Mbps
I dont ever recall in my life seeing upload speeds faster than download speeds. Anyway, I rebooted router, waited 10 minutes and performed the same tests. Here are the results.
Wired
Ping 26ms, DL 120.13Mbps, UL 6.15Mbps
Ping 27ms, DL 121.18Mbps, UL 6.00Mbps
Wireless
Ping 30ms, DL 72.71Mbps, UL 6.07Mbps
Ping 29ms, DL 85.79Mbps, UL 6.08Mbps
