afalcon
Apr 02, 2022Aspirant
NETGEAR AC1750 C6300v2 - Slow internet speed wired and wireless
Modem/router NETGEAR AC1750 C6300v2 ISP: Spectrum firmware: 1.03.04 Some of my devices have drastically low connection speeds when compared to my laptop and phone I have 200mbps plan with s...
- Apr 03, 2022
So I tried to start with the basic troubleshooting and its looks like a factory reset of the modem/router fixed the issue...both wired and wireless have a much improved connection.
The only changes I have made before I noticed the issue was adjust the access control. Other than that I have no idea what could have caused it.
Regardless, I appreciate the list of troubleshooting steps you have provided I will be sure to use them for future reference.
I will observe the connection speed over then next few days and see if anything changes.
Apr 02, 2022Guru - Experienced User
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
afalcon
Apr 03, 2022Aspirant
- FURRYe38Apr 03, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
