afalcon
Apr 02, 2022Aspirant
NETGEAR AC1750 C6300v2 - Slow internet speed wired and wireless
Modem/router NETGEAR AC1750 C6300v2 ISP: Spectrum firmware: 1.03.04 Some of my devices have drastically low connection speeds when compared to my laptop and phone I have 200mbps plan with s...
- Apr 03, 2022
So I tried to start with the basic troubleshooting and its looks like a factory reset of the modem/router fixed the issue...both wired and wireless have a much improved connection.
The only changes I have made before I noticed the issue was adjust the access control. Other than that I have no idea what could have caused it.
Regardless, I appreciate the list of troubleshooting steps you have provided I will be sure to use them for future reference.
I will observe the connection speed over then next few days and see if anything changes.
afalcon
Apr 03, 2022Aspirant
Apr 03, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
