reneandpierrett
Mar 27, 2022Follower
Netgear AC1750 Model C6300v2
I am trying to change my wifi password. I use google chrome and enter the www.routerlogin.net adress in order to give my id and router password but, instead, I always end up with the Netgear web site...
michaelkenward
Mar 28, 2022Guru - Experienced User
reneandpierrett wrote:
I am trying to change my wifi password. I use google chrome and enter the www.routerlogin.net adress in order to give my id and router password but, instead, I always end up with the Netgear web site ???
Which website is that? Netgear has several.
Do you have a different browser you can try?
I downloaded Nighthawk - wifi but it tells me that this program does not work with my Router / modem ??
What tells you that?
Which products support the NETGEAR Nighthawk app? | Answer | NETGEAR Support
Perhaps you have older firmware and your Internet service provider has not bothered to update your version.
