CEV22
Mar 09, 2022Aspirant
NETGEAR AC1750 WiFi DOCSIS 3.0 Cable Modem Router (C6300)
Hi All, I have a NETGEAR AC1750 WiFi DOCSIS 3.0 Cable Modem Router (C6300) purchased new in August and am outside the call support window. I need to remove an old serial number from a previous...
CEV22
I have been trying to work with Xfinity to link it, but they noted that after 4 attempts, Netgear needed to remove the serial number. Their exact feedback is: I am getting the error message that eq couldn't be added to inventory: The serial number already exists, so it may be linked to another account, that is the reason I am unable to add the modem on your account. Please contact your modem manufacturer".
I had registered it to an Xfinity account that no longer exists in August, Xfinity has removed this account, moved to a new state and got rid of my internet, and got a new account recently when settling into a new state. This is my own EQ, not a rental from Xfinity.
Mar 09, 2022Guru - Experienced User
it shouldn't be a serial number you're giving xfinity but the mac address.
And you have to make sure your giving the appropriate one
- CEV22Mar 09, 2022Aspirant
Hi. Yes. I am familiar with serial numbers versus MAC numbers. I have given them both and the issue Xfinity has noted is that the serial is link to another account, so that the MAC number cannot be added. This is not a 'me' issue. It is a system issue.
- plemansMar 09, 2022Guru - Experienced User
yes, with xfnity.
If it worked before the hardware hasn't failed. its xfinity that is having an issue with their system.
If they messed something up in their system, its on them to fix it.
Sure. Though I have gone through Xfinity multiple times and now would like to try here because I am also reading that there may be something Netgear can do to fix it (based on other forums). So I would kindly ask that someone else respond if they have a solution through this.
