cjc15's avatar
cjc15
Tutor
Aug 25, 2025
Netgear AC1900 C7000v2 Downstream Light Flashing
I have had the same provider (Xfinity) and the same modem router for about 14 months.
I had never had this problem before, but starting last week somewhere around 5 times a day the downstream light will start blinking, and the wifi will go down. This blinking will last a couple minutes, then the wifi will still be down for a minute or so after the light goes back to solid. Sometimes this will happen a few times an hour and sometimes it will be perfectly fine for 6 hours.
I have tried reconnecting the coax as well as power cycling a few times but the problem still persists. Does anyone have any ideas on what the issue could possibly be? I have used Xfinity's online wizard which always assures me nothing is wrong, and I could call a tech but would like to be more confident that the problem is actually on the ISP side before potentially having to pay for a tech to come out.
Any ideas / recommendations are welcome!
  • Just closing the loop here, a tech came and said while I was missing a filter, the signal looked fine on their end. They installed a splitter (-3.5db) and a filter. He does not think this was the major cause, and blamed it on the firmware / hardware of the router. Nonetheless, they still covered the cost so no complaints on my end. I have not had internet issues since they came out (Friday August 29) and my signal table seems much more stable based on the links you sent above (all powers below 7dB, 0 uncorrectables and way less correctables).
    Thanks for all your help CrimpOn​ FURRYe38​ , this is hopefully resolved!
    New signal info:
    Downstream Bonded Channels
    ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectables
    1LockedQAM25644705000000 Hz7 dBmV41.4 dB00
    2LockedQAM25624585000000 Hz5.6 dBmV40.9 dB00
    3LockedQAM25625591000000 Hz5.5 dBmV40.2 dB00
    4LockedQAM25626597000000 Hz5.6 dBmV40.3 dB20
    5LockedQAM25627603000000 Hz5.7 dBmV40.5 dB00
    6LockedQAM25628609000000 Hz5.7 dBmV40.1 dB00
    7LockedQAM25629615000000 Hz5.8 dBmV40.7 dB00
    8LockedQAM25630621000000 Hz5.9 dBmV40.4 dB10
    9LockedQAM25631627000000 Hz6.2 dBmV41 dB00
    10LockedQAM25632633000000 Hz6.4 dBmV41.3 dB20
    11LockedQAM25633639000000 Hz6.6 dBmV40.8 dB00
    12LockedQAM25634645000000 Hz6.7 dBmV41.6 dB00
    13LockedQAM25635651000000 Hz6.6 dBmV41.2 dB00
    14LockedQAM25636657000000 Hz6.1 dBmV40.8 dB10
    15LockedQAM25637663000000 Hz6 dBmV40.8 dB00
    16LockedQAM25638669000000 Hz6 dBmV40.2 dB10
    17LockedQAM25639675000000 Hz4.8 dBmV40.6 dB00
    18LockedQAM25640681000000 Hz4.8 dBmV40.3 dB00
    19LockedQAM25641687000000 Hz5.2 dBmV40.8 dB00
    20LockedQAM25642693000000 Hz5.6 dBmV41.4 dB00
    21LockedQAM25643699000000 Hz6.1 dBmV41.4 dB00
    22LockedQAM25645711000000 Hz5.8 dBmV41.5 dB00
    23LockedQAM25646717000000 Hz5.2 dBmV41.3 dB00
    24LockedQAM25647723000000 Hz4.8 dBmV40.8 dB00
    Upstream Bonded Channels
    ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
    1LockedATDMA35120 Ksym/sec22800000 Hz43.3 dBmV
    2LockedATDMA12560 Ksym/sec10400000 Hz41.8 dBmV
    3LockedATDMA25120 Ksym/sec16400000 Hz43 dBmV
    4LockedATDMA45120 Ksym/sec29200000 Hz43.8 dBmV
    5LockedATDMA55120 Ksym/sec35600000 Hz44.8 dBmV
    6LockedATDMA62560 Ksym/sec40400000 Hz44.5 dBmV
    7Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
    8Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
  • CrimpOn's avatar
    CrimpOn
    Typical aerial cable coax lines often develop "issues" over time that lead to intermittent connections.  There have been a number of posts on the Forum describing how the cable tech replaced the entire cable feed.
    My experience is that cable techs carry power level meters and an assortment of attenuators.  My Spectrum tech remarked, "oh. level too high" and installed one.  (free)
  • status log page below, thanks for the help
    Procedure
    StatusComment
    Acquire Downstream Channel585000000 HzLocked
    Connectivity StateOKOperational
    Boot StateOKOperational
    SecurityEnabledBPI+
    IP Provisioning ModeHonor MDDhonorMdd(4)
    1LockedQAM25624585000000 Hz9.8 dBmV40.2 dB110
    2LockedQAM25625591000000 Hz9.7 dBmV39.9 dB90
    3LockedQAM25626597000000 Hz9.9 dBmV40 dB260
    4LockedQAM25627603000000 Hz10 dBmV40.2 dB170
    5LockedQAM25628609000000 Hz10 dBmV39.9 dB170
    6LockedQAM25629615000000 Hz10.1 dBmV40.2 dB10
    7LockedQAM25630621000000 Hz10.2 dBmV40.1 dB20
    8LockedQAM25631627000000 Hz10.5 dBmV40.4 dB420
    9LockedQAM25632633000000 Hz10.7 dBmV40.6 dB270
    10LockedQAM25633639000000 Hz11 dBmV40.3 dB2629
    11LockedQAM25634645000000 Hz11.1 dBmV41 dB390
    12LockedQAM25635651000000 Hz10.9 dBmV40.6 dB90
    13LockedQAM25636657000000 Hz10.5 dBmV40.3 dB190
    14LockedQAM25637663000000 Hz10.4 dBmV40.3 dB80
    15LockedQAM25638669000000 Hz10.4 dBmV40.1 dB250
    16LockedQAM25639675000000 Hz10.2 dBmV39.6 dB70
    17LockedQAM25640681000000 Hz9.2 dBmV39.9 dB00
    18LockedQAM25641687000000 Hz9.6 dBmV40.5 dB00
    19LockedQAM25642693000000 Hz10 dBmV40.9 dB00
    20LockedQAM25643699000000 Hz10.7 dBmV40.8 dB00
    21LockedQAM25644705000000 Hz10.7 dBmV41.3 dB00
    22LockedQAM25645711000000 Hz10.4 dBmV41.4 dB00
    23LockedQAM25646717000000 Hz9.8 dBmV40.8 dB00
    24LockedQAM25647723000000 Hz9.4 dBmV40.3 dB00
    1LockedATDMA45120 Ksym/sec29200000 Hz40.5 dBmV
    2LockedATDMA12560 Ksym/sec10400000 Hz38.5 dBmV
    3LockedATDMA25120 Ksym/sec16400000 Hz39.6 dBmV
    4LockedATDMA35120 Ksym/sec22800000 Hz40 dBmV
    5LockedATDMA55120 Ksym/sec35600000 Hz41.1 dBmV
    6LockedATDMA62560 Ksym/sec40400000 Hz41 dBmV
  • 2025-8-25, 13:57:20Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=54:07:7d:ba:ac:0e;CMTS-MAC=00:01:5c:a7:5a:7b;CM-QOS=1.1;CM-VER=3.0;
    2025-8-25, 13:57:20Warning (5)MDD message timeout;CM-MAC=54:07:7d:ba:ac:0e;CMTS-MAC=00:01:5c:a7:5a:7b;CM-QOS=1.1;CM-VER=3.0;
    2025-8-25, 13:57:20Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=54:07:7d:ba:ac:0e;CMTS-MAC=00:01:5c:a7:5a:7b;CM-QOS=1.1;CM-VER=3.0;
    2025-8-25, 13:52:30Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=54:07:7d:ba:ac:0e;CMTS-MAC=00:01:5c:a7:5a:7b;CM-QOS=1.1;CM-VER=3.0;
    2025-8-25, 13:52:30Warning (5)MDD message timeout;CM-MAC=54:07:7d:ba:ac:0e;CMTS-MAC=00:01:5c:a7:5a:7b;CM-QOS=1.1;CM-VER=3.0;
    2025-8-25, 13:51:03Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=54:07:7d:ba:ac:0e;CMTS-MAC=00:01:5c:a7:5a:7b;CM-QOS=1.1;CM-VER=3.0;
    2025-8-25, 13:51:03Warning (5)MDD message timeout;CM-MAC=54:07:7d:ba:ac:0e;CMTS-MAC=00:01:5c:a7:5a:7b;CM-QOS=1.1;CM-VER=3.0;
    2025-8-25, 12:58:52Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=54:07:7d:ba:ac:0e;CMTS-MAC=00:01:5c:a7:5a:7b;CM-QOS=1.1;CM-VER=3.0;
    2025-8-25, 12:58:52Warning (5)MDD message timeout;CM-MAC=54:07:7d:ba:ac:0e;CMTS-MAC=00:01:5c:a7:5a:7b;CM-QOS=1.1;CM-VER=3.0;
    2025-8-25, 12:58:52Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=54:07:7d:ba:ac:0e;CMTS-MAC=00:01:5c:a7:5a:7b;CM-QOS=1.1;CM-VER=3.0;
    2025-8-25, 12:58:51Warning (5)MDD message timeout;CM-MAC=54:07:7d:ba:ac:0e;CMTS-MAC=00:01:5c:a7:5a:7b;CM-QOS=1.1;CM-VER=3.0;
    2025-8-25, 12:42:05Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=54:07:7d:ba:ac:0e;CMTS-MAC=00:01:5c:a7:5a:7b;CM-QOS=1.1;CM-VER=3.0;
    2025-8-25, 12:42:05Warning (5)MDD message timeout;CM-MAC=54:07:7d:ba:ac:0e;CMTS-MAC=00:01:5c:a7:5a:7b;CM-QOS=1.1;CM-VER=3.0;
    2025-8-25, 12:40:57Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=54:07:7d:ba:ac:0e;CMTS-MAC=00:01:5c:a7:5a:7b;CM-QOS=1.1;CM-VER=3.0;
    2025-8-25, 12:40:57Warning (5)MDD message timeout;CM-MAC=54:07:7d:ba:ac:0e;CMTS-MAC=00:01:5c:a7:5a:7b;CM-QOS=1.1;CM-VER=3.0;
    2025-8-25, 12:29:19Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=54:07:7d:ba:ac:0e;CMTS-MAC=00:01:5c:a7:5a:7b;CM-QOS=1.1;CM-VER=3.0;
    2025-8-25, 12:29:19Warning (5)MDD message timeout;CM-MAC=54:07:7d:ba:ac:0e;CMTS-MAC=00:01:5c:a7:5a:7b;CM-QOS=1.1;CM-VER=3.0;
    2025-8-25, 11:26:44Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=54:07:7d:ba:ac:0e;CMTS-MAC=00:01:5c:a7:5a:7b;CM-QOS=1.1;CM-VER=3.0;
    2025-8-25, 11:26:43Warning (5)MDD message timeout;CM-MAC=54:07:7d:ba:ac:0e;CMTS-MAC=00:01:5c:a7:5a:7b;CM-QOS=1.1;CM-VER=3.0;
    2025-8-25, 10:20:49Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=54:07:7d:ba:ac:0e;CMTS-MAC=00:01:5c:a7:5a:7b;CM-QOS=1.1;CM-VER=3.0;
    2025-8-25, 10:20:49Warning (5)MDD message timeout;CM-MAC=54:07:7d:ba:ac:0e;CMTS-MAC=00:01:5c:a7:5a:7b;CM-QOS=1.1;CM-VER=3.0;
    2025-8-25, 10:20:49Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=54:07:7d:ba:ac:0e;CMTS-MAC=00:01:5c:a7:5a:7b;CM-QOS=1.1;CM-VER=3.0;
    2025-8-25, 10:13:11Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=54:07:7d:ba:ac:0e;CMTS-MAC=00:01:5c:a7:5a:7b;CM-QOS=1.1;CM-VER=3.0;
    2025-8-25, 10:13:11Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=54:07:7d:ba:ac:0e;CMTS-MAC=00:01:5c:a7:5a:7b;CM-QOS=1.1;CM-VER=3.0;
    2025-8-25, 10:13:11Warning (5)MDD message timeout;CM-MAC=54:07:7d:ba:ac:0e;CMTS-MAC=00:01:5c:a7:5a:7b;CM-QOS=1.1;CM-VER=3.0;
    2025-8-25, 09:11:49Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=54:07:7d:ba:ac:0e;CMTS-MAC=00:01:5c:a7:5a:7b;CM-QOS=1.1;CM-VER=3.0;
    2025-8-25, 09:11:49Warning (5)MDD message timeout;CM-MAC=54:07:7d:ba:ac:0e;CMTS-MAC=00:01:5c:a7:5a:7b;CM-QOS=1.1;CM-VER=3.0;
    2025-8-25, 09:11:49Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=54:07:7d:ba:ac:0e;CMTS-MAC=00:01:5c:a7:5a:7b;CM-QOS=1.1;CM-VER=3.0;
    2025-8-25, 08:08:20Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=54:07:7d:ba:ac:0e;CMTS-MAC=00:01:5c:a7:5a:7b;CM-QOS=1.1;CM-VER=3.0;
    2025-8-25, 08:08:20Warning (5)MDD message timeout;CM-MAC=54:07:7d:ba:ac:0e;CMTS-MAC=00:01:5c:a7:5a:7b;CM-QOS=1.1;CM-VER=3.0;
    These timestamps found in the event log seem to correlate with the outages, but I am not familiar enough with networking to understand what they mean. Assuming this is the key here, based on other approaches it seems the solution is to troubleshoot with ISP but the tech won't know much about it. Is that understanding correct?
