ine1's avatar
ine1
Follower
Aug 08, 2019
Netgear AC1900 C7100V Tel lines
Is there a way to have the Tel 1 and Tel 2 jacks default to the same phone number so I can plug in two devices.
Currently only Tel 2 works while plugging in the phone and don't get a dial tome on Tel 1?
  • FURRYe38's avatar
    Sounds like a faulty jack or modem. I believe both jacks should be on the same line. Might contact NG support and ask about this.
  • vkdelta's avatar
    vkdelta
    NETGEAR Employee Retired
    typically it was supposed to be for home alarm feature. did you ask comcast if both lines are provisioned?
    is the Tel1 LED lit?
