Hybrid042785
May 26, 2020Initiate
Netgear AC1900 Cable Modem Voice Router C7100v Lights flashing intermittent no wireless or lan conn
The router stopped working. I cannot connect via wireless or lan. The router will not even factory reset.
Hybrid042785
May 27, 2020Initiate
Thanks for your suggestion. I contacted Netgear support last night and they will send me an rma.
May 27, 2020Guru - Experienced User
Good to hear. Hope the new unit works well for you.
Good Luck.
