oldvern
May 08, 2022Aspirant
Netgear AC1900 mod.c7000v2 port forwarding
I need to open some ports to allow a wifi device to commutate with manufacturer . I have downloaded the instruction fom netgear support . Not able ( or not sure ) whar ip`s they asking for . Keep get...
May 08, 2022Guru - Experienced User
what errors are you getting?
Its tough to help without info/photos/better descriptions of what you're putting in and attempting to do
oldvern
trying to add this device , A = these are the numbers i put in . get error IP address not in lan . invalid server .I guess I dont know what they are asking for .
- plemansMay 09, 2022Guru - Experienced User
You're right. its not in your lan.
In your one photo, you're setting your port forwarding settings for 192.168.51.1
But the next photo is showing your router's lan range is in the .0 range (192.168.0.***)
- oldvernMay 09, 2022Aspirant
how do I fix this ? not my forte . thanks for your help.
tough to tell you have to fix it because its usually a bit specific to your device.
You should be port forwarding to devices in the same subnet. So if you're router is on the 192.168.0.1 lan address, the devices should be 192.168.0.*** where the *** is the device specific ip address. You'd need to be using that address to forward to the device
