oldvern
May 08, 2022Aspirant
Netgear AC1900 mod.c7000v2 port forwarding
I need to open some ports to allow a wifi device to commutate with manufacturer . I have downloaded the instruction fom netgear support . Not able ( or not sure ) whar ip`s they asking for . Keep get...
oldvern
trying to add this device , A = these are the numbers i put in . get error IP address not in lan . invalid server .I guess I dont know what they are asking for .
May 09, 2022Guru - Experienced User
You're right. its not in your lan.
In your one photo, you're setting your port forwarding settings for 192.168.51.1
But the next photo is showing your router's lan range is in the .0 range (192.168.0.***)
