Jtf12345
Jun 12, 2020Aspirant
Netgear ac1900 warranty refusal
I purchased my Nighthawk router on July 26, 2019 from Best Buy. It has worked fine until about a month or so ago. The router no longer allows internet access. We have been through technical support wi...
Jun 12, 2020Guru - Experienced User
What is the model# of the AC1900 product, NG has different products with AC1900.
All we can do here in the forums is troubleshoot to see if the problem can be resolved, if not, you'll need to contact NG support. I would suggest sending a PM to a forum moderator to see if they can help you out.
- Jtf12345Jun 12, 2020AspirantThanks for the reply. The model number is C7000v2. I will send a message to the moderators as you suggested.
