Jeromeste22
Mar 24, 2020Aspirant
Netgear as router mode (netgear 7000p
Hi i have à huawei hg8245h modem/router 2in1 with my netgear 7000p i want to use full feature of the netgear problem is my isp dont allow bridge connection, so i have to use isp and netgear in router ...
Mar 24, 2020Guru - Experienced User
If you're ISP doesn't allow bridge mode/passthrough/dmz then you might not be able to run the full features of the netgear without running into the issue you're having. Its unfortunate that your isp has locked it in that way.
ATT is another provider that is good at not allowing or having poorly running passthrough mode.
