jonahmiles7
Sep 19, 2020Follower
Netgear AX6000 Wifi Cable Modem Router WPA3 Security?
I just purchased the brand new AX6000 WiFi Cable Modem Router. It says it is an 8-stream WiFi 6 Cable Modem. However it does not have WPA3 security for WiFi. I thought all WiFi 6 cable routers wer...
Lurksalot
Sep 24, 2020Apprentice
jonahmiles7 I assume you're talking about CAX80. This equipment isn't required to have anything specific to Wi-Fi 6 if it isn't officially Wi-Fi 6 certified. From discussions here I don't think there are Netgear Wi-Fi 6 devices certified (I could be wrong, so someone please correct me). On top of that, CAX80 firmware will likely not be updated by the ISP (Internet Service Provider) - see discussion in the third link below (not CAX80 specific but nonetheless the topic applies).
Here are a few good discussions on the topic.
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/RAX120-is-dead-does-NOT-fully-supp...
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/RAX120-UL-OFDMA/m-p/1958111
- FURRYe38Sep 25, 2020Guru - Experienced User
If and when they decide to add WPA3, hopefully NG can push this to users since the CAX80 supports the router portion of the modem being updated by users. I believe the modem portion FW is still reserved by the ISP though.
