net1245
Nov 05, 2024Aspirant
Netgear Ax8
I have this Ax8 router. Factory settings + Limit 5G to 1200M Limit 2.4 to 600M I am on a Giga bit network and get 800M on 5G and only 100 on 2.4g My OBS streaming does not work if I ...
Nov 05, 2024Guru - Experienced User
What channel configurations are currently set on the router?
Is Smart Connect Enabled or disabled?
Is this the only item that has problems on 5Ghz?
Is all wifi feature options enabled under Advanced tab/Advanced/Wireless settings?
Has a factory reset and setup from scratch been performed since FW was updated?
net1245
Nov 13, 2024Aspirant
1. Channel is set to AUTO for 4G and 36 for 5G. I have tried Auto for 5G as well
2. Smart connect is disabled (No check)
3. This is the only item (OBS) that I have tried that has this problem. The same application with the exact same settings performs just fine on the 4G
4. Correct all boxes are ticked.
and yes, factory reset was done at least 3 times. and the firmware is update
