HIROLLER's avatar
HIROLLER
Follower
Oct 26, 2016
Netgear c 3700 had to do a factory reset router it froze up.nOne can't get into router with genie
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello HIRoLLEr
    Are you able to login after the factory reset?
    DarrenM
