Adm1n420
May 07, 2020Follower
Netgear C-6300 downlink won’t stop blinking
Light keeps blinking. Cant get a good internet signal.
I have reset the modem/router combo multiple times. Sometimes the WiFi wouldn’t show up.
This is new install
This is new install
1 Reply
1. do you have it hooked to coax?
2. Any splitters, attenuators, or amplifiers in line?
3. Is it connected right where the coax enters the home? Sometimes there's issues with the wiring in the home so its best to start at a known good location.
4. has it been activated by your isp? You can call in to get it activated by the isp.
5. if you log into it (can do over an ethernet connectin) and click on cable connection, take a screen snip of that info plus your logs and post it back here.
