matrix1781
Nov 17, 2015Aspirant
Netgear C3000 LAN speed ok slow wifi
hi I have a netgear C3000 modem. My ISP is Comcast and the plan speed is 50MPS. My wired conenction seems to yield that speed but wireless drops to 12MBPs or even 5 MBPs most of the time. Tried c...
Babylon5
Nov 18, 2015NETGEAR Employee Retired
Do those devices you listed show the same effect at the same time?
matrix1781
Nov 18, 2015Aspirant
When I do a speed test I am getting similar speeds on my phone and mac? Today it was about 20MBPs after I rebooted the modem.
- Babylon5Nov 19, 2015NETGEAR Employee Retired
Can you run a LAN-LAN throughput test using a utility like Netstress or similar? This might help identify where the loss of throughput is occurring. It may also help to repeat that test at a different location e.g. a friend or relative’s house, a LAN-LAN test should not need an Internet connection. How long does it typically take for the throughput to drop?
- va_c3000_sjNov 23, 2015Aspirant
We just activated a new C3000.
If I connect the laptop using a cable to the Modem-ROuter(C3000) , I get a speed test result of 70+ MBPS.
When I connect using wifi , I do not get beyond 20MBPS.
I have configured it to Channel 9 reviewing all used channels in the vicinity.
The router is supposed to support 300MBPS . so why cann I not go beyond 20MBPS.
I checked the mode that is also set to be at 150Mbps.
Can you help?
Vijay
- md_faiz_aliNov 25, 2015Guide
I have n600 and facing same problem. Speed is good over wired LAN but very poor over wifi. I have raised issue with FCC
