matrix1781
Nov 17, 2015Aspirant
Netgear C3000 LAN speed ok slow wifi
hi I have a netgear C3000 modem. My ISP is Comcast and the plan speed is 50MPS. My wired conenction seems to yield that speed but wireless drops to 12MBPs or even 5 MBPs most of the time. Tried c...
ahastings1
Dec 01, 2015Aspirant
I have same problem. 150 mbps wired lan but only 35 mbps wireless. I just purchased this modem so I put in a support case with netgear. if I get a solution will post up
md_faiz_ali
Dec 01, 2015Guide
Its of no use. Everyone using N600 are having the same issue. I have raised a complaint with FCC that ticket is currently being reviewed. Requesting everyone reading this and having same issue to raise ticket with FCC so the false advertisement regarding data rate should be rectified by netgear
- Srk1Jan 17, 2016Initiate
The issue with wifi is seems to be unversal across if both modem/Router are in on device.
A week back I got ARRIS SBG6580 and had terrible issues with wifi reception and speed though over cable speed was good.
I returned and bought this C3000 and spent over 30 mins with Comcast tech support but in vain. I have 75MBPS speed and over wifi I'm getting maximm 15 MBPS.
Not sure whom to contact for the solution. Comcast or Netgear.
I'm going to summarize and report to FCC over these deceptive manufacturers
