matrix1781
Nov 17, 2015Aspirant
Netgear C3000 LAN speed ok slow wifi
hi I have a netgear C3000 modem. My ISP is Comcast and the plan speed is 50MPS. My wired conenction seems to yield that speed but wireless drops to 12MBPs or even 5 MBPs most of the time. Tried c...
twessman88
Apr 07, 2016Aspirant
I am having the same issue. It literally stopped working at day 91. Very convienent. My speed with Ethernet is over 90mbps and without is 2mbps. Anyone have any ideas on how to fix this?
DarrenM
Apr 13, 2016Sr. NETGEAR Moderator
Hello twessman88
Have you tried to adjust the WIfi channel to see if this improves the wifi speed?
DarrenM
- stewilliams138May 19, 2016Aspirant
Hey,
I just bought this item had the same issue, troubleshooted this several times with Netgear no avail. Changed wireless settings, the fragmentation legnth ect, nothing worked. I got frustrated because I did not know if it was my OS or the new modem/router. I did know that my mac was getting good wifi signals most of the time at the correct speeds, just not my windows PC. I finally gave the mode/router one more shot and went into the settings 192.168.0.1 go to advanced settings/administration/router mode. Ensure that this is turned on. By default, nothing is filled. I think this is the reason for the inconsistent signals I was getting prior. It's not guarantted to boost your speed that you were exp prior, but it should fix the overal connection you were getting, it definitely increased my connection and speed; although the speed test dont really reflect any changes on internet speed test sites. I am still running the original version 1.0.1.11 and have not updated that and this is not a prb and my ISP is Time Warner Cable. Hopefully this fix helps you, not sure why the default for router mode is not on "yes".
Hope this helps.
- JonoregonSep 09, 2016Tutor
DarrenM wrote:Hello twessman88
DarrenM
Yes I have. I did get up to 25 Mbps for a few hours. No where near the 80 Mbps wired.
- manueljgrDec 24, 2016Initiate
I also Have the same issue for a long time. I have tried all possible recommended solutions
wired conecction ok, wireless connection bad. I only get 10-20 out of 100 Mbps
My service provider is TWC, now Spectrum. To whom do I have to complain?
Manuel
