Jitao
Oct 08, 2019Aspirant
Netgear C3000 N300 WiFi cable modem router
I’m netgear C3000 suddenly doesn’t work. It showed power light is solid red and the other light is solid green. But it is no WiFi , no internet. And I try to reset it. But I cannot. How can I do? Just...
Oct 08, 2019Guru - Experienced User
There's a whole bunch of leds on the front. You explained some colors but not what specific each light was. Page 7 of your manual lists what each light is. Try telling us what each is doing.
Also there is the option of resetting the device using the reset button. Push and hold for 7-10 seconds. you stated you can't reset. Why not?
You can also contact your isp to have them resend the configuation file for it.
Here's you support site with manuals, troubleshooting, etc.
https://www.netgear.com/support/product/C3000.aspx
It also has a 1 year warranty if its new.
Jitao
Spoiler
Spoiler
plemans wrote:There's a whole bunch of leds on the front. You explained some colors but not what specific each light was. Page 7 of your manual lists what each light is. Try telling us what each is doing.
Thanks, Plemans. I said I did reset it, but nothing is happened. And if I power on the device. It showed power light is solid red. I show you the picture. Thanks!
