Jitao
Oct 09, 2019Aspirant
Netgear C3000 N300 WiFi cable modem router
I’m netgear C3000 suddenly doesn’t work. It showed power light is solid red and the other light is solid green. But it is no WiFi , no internet. And I try to reset it. But I cannot. How can I do? Just...
Jitao
I have already signed another modem that my ISP gave me. So I can not use mine for the internet. Thanks!
Oct 09, 2019Guru - Experienced User
Have someone check the power adapter for the modem. If it's good then the modem is probably bad. If the power is bad then the power adapter can be replaced.
Good Luck.
