Freddgo
Sep 20, 2016Follower
Netgear c3000 slow internet wifi
Hi; I have a problem with my Netgear C3000, I have a Comcast Internet speed up to 75 MB but when I test the Internet conection the max Interntet I get is 30 MB (wired), I restarted the modem, unp...
DarrenM
Nov 29, 2016Sr. NETGEAR Moderator
Hello bprometheus72
Have you tried to change the wireless channels you may even want to try and lower the data rate on the wireless see if that will get faster speeds on the wifi.
DarrenM
bprometheus72
Dec 02, 2016Aspirant
Yes - I did. It didn't work also. Finally I got fedup and asked Xfinity to supply their own cable modem, which works beautifully giving speeds of 180 MBPS wireless (it has 2.5 Ghz and 5 Ghz).
I recently bought a range extender also and that has the same problem as other netgear equipment.... speeds don't exceed 25-30 MBPS... Something wrong about these routers vs what's advertised by Netgear... very misleading.
- shnDec 04, 2016Aspirant
bprometheus72 which cable modem from Xfinity did you purchase? Was it a modem router combo? I have having the same problem with Netgear C3000 and with the many complaints i saw on Netgear community I don't think netgear was able to provide any solutions.
