TerryC
Sep 07, 2017Aspirant
Netgear C3700 Modem/Router
my internet service provider is Comcast/Xfinity - I've had half a dozen service calls, new wiring new this speed tests by different technicians and this evening I'm told that it's my personal rout...
DarrenM
Sep 11, 2017Sr. NETGEAR Moderator
Hello TerryC
Is it 10 Mbps on wireless or on wired connections or both? Also did you upgrade to the C3700 recently it could be a coding issue on comcasts side where your old modem is still set to 100 mbps and your new one is set to the default 10.
DarrenM
- TerryCSep 16, 2017Aspirant
thanks for the suggestion on how to fix it but there isn't any place on Subscriptions and notifications to change Settings ? so I'm still not able to fix the issue
