Shyrage
Feb 05, 2019Aspirant
Netgear C3700 (N600)
I have this modem/router just laying around and I wanted to go ahead and make use of it again. I was curious if I could use this as just a wifi extender since I already have a main router/modem from my internet provider Grande. Any way of making this happen? Any help would be nice, just tell me what I need to do, thanks!!
> [...] if I could use this as just a wifi extender [...]
That depends on what "a wifi extender" means to you. You should be
able to configure it as a wireless access point (with a wired connection
to the main router). See, for example:https://community.netgear.com/t5/x/x/m-p/1463500
That's written for a C6300, but the steps are about the same for any
other router (any make/model) which lacks a one-step WAP option,
including yours.- ShyrageAspirant
Ok, so I can't use as a wireless access point like my old Rangemax wireless router WPN824 v3? What I mean is that I'm using this C3700 on the other side of the home. There's no way a long line of Ethernet can run from that room all the way to the living room where the main Modem is. Can't I just plug it into a switch or something? What changes on the device itself should I be making for the setup?
> wireless router WPN824 v3? [...]Do I know what you did with your "my old Rangemax wireless router
WPN824 v3"? (Hint: No.)Does your "my old Rangemax wireless router WPN824 v3" have a
WAN/Internet Ethernet port? (I'd assume yes.) Does your C3700 have a
WAN/Internet Ethernet port? (I'd assume no.) So, can you directly
substitute a C3700 for a WPN824v3? Not in all cases.> [...] What I mean is [...]
You lost me. What, exactly, do you think that you can or can't do
(and why)?> [...] Can't I just plug it into a switch or something? [...]
Plug what into what? Why?
> [...] What changes on the device itself should I be making for the
> setup?If "the device itself" means the C3700, then that depends on what you
intend to do with it. If you want to use it as a wireless access point
(which, I'd expect, is about the only thing which you could do with it),
then that's what that cited thread tries to explain.
