Shyrage
Feb 04, 2019Aspirant
Netgear C3700 (N600)
I have this modem/router just laying around and I wanted to go ahead and make use of it again. I was curious if I could use this as just a wifi extender since I already have a main router/modem from...
antinode
Feb 05, 2019Guru
> Ok, let me try to make this as easy enough. [...]
It didn't work. Please try to remember that the non-psychics in your
audience can't see what you can see.
> [...] there's no way I can run the cord from point a to point b. With
> this not being an option, is there another way of making it happen?
If you get more hardware. There exist Powerline devices which can
(typically in a pair) use your building power wiring to emulate an
Ethernet cable. So far as I know, the only useful way to add a C3700 to
an existing (modem+)router would be to configure it as a WAP, and that
requires a wired connection (or equivalent) to the main (modem+)router.
> [...] The current router that I have in the bedroom is an old Netgear
> Range Max wireless router. [...]
How is _that_ connected to anything?
> [...] I do have a switch connected to the old Netgear range max
> router, which is how I'm able to have it on for the output of wifi.
What, exactly, is connected to what, exactly? Hint: If a device has
multiple Ethernet ports, then "connected to device" is not enough
detail.
> [...] When I plugged in the c3700 in its place [...]
See "What, exactly, [...]", above. And how did you configure the
C3700 before/when you did that?
> [...] a main router/modem from my internet provider Grande. [...]
What is that device? To what is it connected (how)?
Shyrage
Feb 08, 2019Aspirant
Finally gave up on the whole thing and purchased two MoCA adapters. Using the internet through the existing cable line is the way to go, no drop in speeds. Thank you for you're helping.
