JimCurry
Dec 19, 2023Follower
Netgear C3700 Question
I've used the C3700 with Xfinity since 2015. We had a power failure and after power restoration none of my computers, phones, cameras, tvs see either the 2.4 or 5 wifi signals. The ethernet connect...
Dec 19, 2023Guru - Experienced User
Did you push and hold for at least 2 seconds on the wifi on/off button?
Also, it might be time to upgrade. Thats a pretty low performing modem with a N600 router.
Its pretty old/slow. Unless you're paying for the most base model speeds, you might see a nice improvement in speeds by upgrading to something from this generation
